Dell Wireless Keyboard Optical Mouse w0147 Logo
Posted on Oct 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My keyboard was working fine and all of a sudden it has started repeating the keys, not responding at all. One minute it is fine, the next it starts doing it all over again. I have put new batteries in, shut the computer down, checked to see if the drivers needed update, but the system says they are updated. Please help
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 226 Answers
  • Posted on Oct 21, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
226
Questions
0
Helped
40685
Points
592
See if the same problem is there in bios . Then try a recovery if all fails.
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Hyundai 2003 sante fe starting problem
    Check all battery and ground connections and clean them.You may have a bad relay or starter also.
    Hello, i HAVE AN ACer laptop, AND AS YOU Can see the cAPSLOCk key turns on and off randomly. In addition the toucHPAD LOCks up until i hit a key, THEN IT WILL WORK AGAIN FOR A FEW MINUTES. fINALLY , the...
    Hello vickiek42, these instructions will help you, first, click on the "Start" button, in the "Start Search Window, Type: keyboard; the "Keyboard's" Properties window will open. You can (Test) to see exactly how your keyboard is responding. if you are still having the same problem, (check the Keyboard Status), try "Updating the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; try "Uninstalling the Keyboard. To "Uninstall the "keyboard," do the following. Shut-down (turn- off completely), Next, turn-on the computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the computer. You will repeat exactly what you did from the start, this will "Reinstall the Keyboard. Restart the computer again after all changes have been made; this will ensure the changes take place properly.
    • Next, I will guide you through the steps to fix the "Touch Scrolling." First, click on the "Start Button" paul7of9_43.jpg in the (right, pane) select to open the Control Panel: next open the [Hardware and Sound] category, paul7of9_44.jpg click on the "Mouse" applet. Next, in the Mouse Properties" (window) click on the "Device Setting" button, paul7of9_47.jpg once the window open, click on the "Settings" button just below the "highlighted" (Name) of the device: Synaptics TouchPad. paul7of9_48.jpg Try out some of the "items listed" Tapping, Virtual Scrolling... "You must click on the "Apply and OK buttons when finished. " Note: Restart the computer; this will make sure the changes are correctly applied, and working properly. "Rating the solution will let me know if the problem is fixed, or you will need further assistance, thanks for using FixYa, paul7of9"
    1helpful
    Logithech keyboard
    Hi, these instructions will help you, first, click on the "Start" button, in the "Start Search Window, Type: keyboard; the "Keyboard's" Properties window will open. You can (Test) to see exactly how your keyboard is responding. if you are still having the same problem, (check the Keyboard Status), try "Updating the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; try "Uninstalling the Keyboard. To "Uninstall the "keyboard," do the following. Shut-down (turn- off completely), disconnect all the Keyboard Devices that are attached to the computer. Next, turn-on the computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the computer. You will repeat exactly what you did from the start, this will "Reinstall the Keyboard. Restart the computer again after all changes have been made; this will ensure the changes take place properly. "Rating the solution will let me know if it worked, or you may need further assistance, thanks."
    2helpful
    I just got a key for my 1998 cadillac sts but it will not start the car what do i do? It will open the doors and the alarm goes off but the car will not start.
    Leave key in ignition and turn to ON (do not start) Leave in on position for exactly 10 minutes. After 10 minutes is up and your anti-theft light is off, then immediately start the car.
    Sometimes the key also need to be reprogrammed for the car.
    insert the key and turn the key to "on". The DIC will say "Remove Key, Starting Disabled", and the security light will remain on.
    approx. 10 minutes later. Remove the key. wait 10 seconds and repeat this another two times, for a total of 30 minutes "key-in" time.
    Now insert your key and start the engine.
    To learn additional keys:
    Start the engine up with a working key. Shut the engine off, and within 10 seconds, insert the next key you want to learn and turn it to "ON". When the security light goes out, that key is programmed. Repeat for the next key, up to 10 keys can be programmed per car.
    Won't start sometimes
    Hmm, sounds like starter. Next time it will not start, don't hold the key for almost a minute. Try turning the key several times if no luck, grabb a hammer and LIGHTLY tap on starter. If it turns over normally then, starter is going out.
    1helpful
    2answers
    Keyboard responds time
    To adjust the key repeat rate
    1. Open shortcutcold.gifKeyboard in Control Panel.
    2. On the Speed tab, make changes as follows:
      • To adjust the amount of time that elapses before characters repeat when you hold down a key, drag the Repeat delay slider.
      • To adjust how quickly characters repeat when you hold down a key, drag the Repeat rate slider.
    note.gif Note
    • To open Keyboard, click Start, click Control Panel, click Printers and Other Hardware, and then click Keyboard.
    Good luck and please rate me
    2helpful
    2answers
    Keyboard not responding
    Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
