I need an excel formula to return the sum of the greatest run of consecutive numbers can anyone help? Thanks
Hi, Not sure if this is what you have tried:
1: Assuming each run is on a different column
Run1 Run2 Run3 Run4, etc...and the maxium lenght of each column is 9 values, but each colum has a different lenght of numbers..
Then you can use:
=MAX(COUNTIF(A2:A10,"<>0"),COUNTIF(B2:B10,"<>0"), {keep adding countif for each colum).
If all runs are on the same colum, then using Pivot tables is easier. If you have a copy of your data, please post it so that I can give you the exact formula ;)
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
