Minolta Maxxum 400si 35mm SLR Camera Logo
Posted on Dec 30, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens can you use a chinar 80-205mm telephoto zoom lens made for a minolta 35mm slr camera on a minolta maxxium 400si camera type of focus of lens is manual. if not can you recommand some zoom lens for the camera thanks richard
Anonymous
Level 3:
  • Master 667 Answers
  • Posted on Dec 30, 2007
Anonymous
Master
Level 3:
Answers
667
Questions
0
Helped
221689
Points
1593
Sorry, the mounts of Minolta manual focus lenses are different than their auto focus series. Sigma, Tokina and Tamron all make compatible zoom lenses to fit the Maxxum series cameras
How to put camera in automatic focus
The af/manual switch is located on the side of the mirror box. However, this model was notorious for failure of the auto focus motor. Also check the lens to make sure the focus moves smoothly (take off camera)
My tilt/shift lens isn't working with my Minolta Maxxum 400si - the aperture which is controlled through the lens won't communicate with the body, is there a way around this?
Is this an auto focus lens? Most shift lenses are manual focus. Also, because they shift, they can generally only be used on manual not he auto settings. If the contacts are not on the back of the lens then it will on communicate with the body
2helpful
What size lens do i need for this camera?
You just need any Minolta AF mount lens. Sony Alpha lenses also physically fit as Sony inherited the Minolta lens mount when they bought the company, but as they are a later development not all will be electronically compatible.
The size of the lens depends upon the focal length of the lens and you choose that according to how wide a field of view you desire. Typical lenses are 28 and 35mm wide angles, 50mm "standard" (approximately the same perspective of how the human eyeball sees images), 70 to 90mm short telephoto lenses (a narrower perspective and very good for portraits) and higher numbers are narrower perspective telephoto lenses for viewing increasingly distant objects. In practice, the available lenses will be incorporated into zoom lenses which incorporate a seamless range of focal lengths within one single model. The word "zoom" reflects the fact that you can seamlessly change from say 28mm wide angle through to 80mm short telephoto and every single setting between them
Any zoom which starts at less than 50mm and finishes in the short telephoto range is called a standard zoom and is the lens that most autofocus cameras were supplied with. The next most common size will be something like a 70-200mm which is a telephoto zoom (or tele zoom) and takes you from a portrait lens to a genuine 5x magnification telephoto. You may also find so-called "super zooms" which do the whole job on one, for example 28-200mm. but the more jobs a single lens tries to do, the bigger and bulkier it becomes and the image quality deteriorates due to poorer contrast and greater image distortion at each end of the zoom range.
This is not an exhaustive answer, as there are entire books on the subject, but hopefully it's been of help to you.
Please take a moment to rate my answer or to add a comment if my answer has left you with unanswered questions which need to be resolved before you can rate my reply.
What size lens does this camera use?
Hello kry...With a large selection of lenses, the Konica Minolta 400SI offers a range from super wide fisheye to 600mm super telephoto. Joe
Thanks for choosing Fixya!
1helpful
Is it possible to manually control the shutter speed, aperture, AND the focus on the Konica Minolta Maxxum 400si SLR 35mm film camera? I need to be able to manually control these features for a film class...
Yes. You have full control over the shutter speed and aperture in the Manual exposure mode, as described in the "M Mode: Manual Exposure" section in the manual.
You also have full control over the focus, as described in the "Manual Focus" section in the manual.
If you need a manual, you can download it (in two parts) from
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Is it possible to manually control the focus on this camera? (Konica Minolta Maxxum 400si SLR 35mm Film Camera) I need to be able to manually control the focus, apeture, and shutter speed for a film...
The description of the manual focus is available in part 2 of the manual, page 40. The manual is available as a PDF here: http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html#si_series . It is the seventh camera in the SI series in the list.
To manually focus the lens, press the focus-mode button on the front of the camera (bottom left when you are behind the camera) until M. focus appears in the data panel. If you have an AF lens, turn the focusing ring until the subject appears sharp. If you have an xi-Series or AF Power Zoom lens, pull and turn the lens control ring.
The focus indicator will light when the subject is in focus. To return to autofocus mode, press the focus-mode button again. The camera will also return to the autofocus mode if you press the program reset button.
I hope this helps.
(in manual focus, you can take a picture even if the subject in the focus frame is not in focus. Often it means you need to take multiple pictures to get a good shot of the subject. The advantage is that you can get some interesting shots.)
1helpful
What size lens fits a Minolta Maxxum 3xi??
It depends entirely upon what you're after and the type of photography you wish to undertake.
Any Minolta AF mount lens will fit. 28mm is a standard wide angle, 50mm is a standard lens with a field of view approximately the same as the human eye, 80mm is a slight telephoto and for distant subjects 200mm is a long telephoto. Some lenses combine a few into one, they're called zoom lenses and will typically be something like 35-70mm, or 70-200mm. The measurements relate to the focal length of the lens, but generally the larger the number the longer the lens sticks out at the front. Zoom lenses are bulkier and heavier than fixed focal length lenses, but they're also the most commonly used types these days.
1helpful
Trying to use a Phoenix 500mm telephoto lens and the shutter won't release
Some longer Tele lenses extend into the camera and prevent the mirror from moving up on some models with larger mirrors. One solution> get a 1.4 teleconverter It will add some space between camera and lens. Two solution> buy another Maxxum body on Ebay. Some Maxxums can be bought very cheap.
35 mm minolta maxxium 5 w/ a af zoom
after loading new film roll and after taking first snap, automatically rewind the roll and coulnttake any photo,,,,,,,,,
Top Minolta Photography Experts
ZJ Limited
ZJ Limited
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
