Question about RIM BlackBerry Pearl 8100
Rollerball not working
Tonight the rollerball on my Blackberry Pearl will not work in the upward direction; only the downward direction. Is this something I can fix or is this a hardware problem?
  • 16 more comments
  • Anonymous Mar 06, 2008
    Today the rollerball on my Blackberry is not effectively working in a downward direction.  When i get home later i will try to take the silver rim off and clean the ball but it seems like a potentially risky process if i do it wrong!  Is there any other solution to this problem??
  • oxfordcdrink Jul 20, 2008
    my roller ball will not roll downward
  • wjb1060 Jul 21, 2008
    Similar problem. Up and down is ok but the track ball won't move the curser right or left.
  • mybook01 Jul 23, 2008
    The rollerball in my blackberry pearl 8100 moves eratically. mostly moving laterally. No up or down movement at all
  • Purple Star Jul 31, 2008
    My rollerball would only operate vertically and I followed the soultion offered above but didn't have rubbing alcohol so used fingernail polish remover and fixed it! Thanks!!!
  • inperpetuity Aug 06, 2008
    My BB roller ball won't scroll up. This has happened before but it seemed to spontaneously start up again hours later without my intervention.
    It doesn't seem to be gunked up with dirt or dust but certainly could be considering the abuse to which I subject it. (I'd keep it in a case but then can't hear it ring no matter how I adjust the volume).
    Please help me.
    Thank you.
  • mheard3 Aug 09, 2008
    my roll ball doesnt go from left to right but it does go up and down what do i do
  • Anonymous Aug 15, 2008
    Rollerball want go dn
  • penny5053 Aug 21, 2008
    my rollerball will go down but not up or sideways
  • losasso Sep 08, 2008
    It starts to type random numbers - mostly x and 7. the whole phone just freezes. I took the battery out and nothing changed.
  • Anonymous Oct 11, 2008
    Rolerball only scroll right
  • halleye Oct 12, 2008
    Same problem, except mine won't go down.
  • Anonymous Nov 11, 2008
    Rollerball would move, but not scroll up on screen. Took it apart as described on this site and it WORKS!!!!
  • tylerprod Dec 02, 2008
    My rollerball on my pearl only scrolls up, down and to the left. I cannot get it to scroll to the right. Any suggestions?
    J~
  • Anonymous Dec 05, 2008
    won't roll down. up left and right are fine.
  • Anonymous Dec 19, 2008
    It would not scroll down, I cleaned it and now it scrolls down but doesn't select by pushing down -- HELP!
  • Anonymous Jan 30, 2009
    same as above
  • jazz91889 Feb 27, 2009
    my roller ball doesnt move to the right side or downward. only up. what should I do?
  • 97 Answers
RIM will admit, its a known issue with the blackberry 8100...it was the first blackberry with a front trackball and so there is a design flaw that dust will get in here and prevent the magnets from moving around inside.
the little silver rim is acutally designed to be taken off so you can clean inside. take an embrodery needle, and put it under the silver rim by the TY button on the keypad....once this pops off, there is the ball and there are 2 more silver rims inside along with 4 magnets. remember how you take this apart, cause if you dont, then this will void any warrenty your phone might have.
in order to clean this, soak the ball in rubbing alchohol and take a cotten ended Q-tip with rubbing alchohol and damp it a little bit and clean it real well.....its also nice preventative doing this regularly...,. (not taking the ball out, but just cleaning the rim and ball about once every other day or so....)
Posted on Jan 02, 2008
    New Friend:
  • 117 Answers
The silver ring which covers the trackball can easily be removed if you use a small screwdriver to lift it at the outer side of the ring. Be careful here! Like you should be during the whole process as all parts have very small plastic nipple which can break very easy. When the silver plastic ring is removed you will see the inner trackball component which can be removed completely. Before doing this you should carefully remove the silver metal ring that holds the trackball component in its position. The trackball component itself can also be carved. For every direction the ball can roll to you’ll find a sensor wheel. Those wheels are mostly carrying some gunk you should clean them from. Once this is done put everything back together to the place the pieces came from and secure the trackball with the silver plastic ring you removed in the first step. Your BlackBerry’s trackball should be back working now.
There are pictures of how to do this on "other" forums.
Gadget
Posted on Dec 05, 2008
Mine was Blackberry 8820.
It's been a while that I was not able to move upward using my rollerball. Today was the final straw and I was especially frustrated when the provider "TMOBILE" does nothing to help. I snapped open the silver ring that goes around the rollerball using a small sharp steak knife. Basically applying a little pressure after putting the tip of the knife underneath the silver oval. Inside it is the rollerball and the rest of the stuff that connects to it. I used Dust Off air blaster and blow the bottom of the rollerball, as well as the rest of the removed pieces. Next, i dipped all the removed pieces into several teaspoons of water (w/ a tiny bit of soap), and brushed it gently with an old toothbrush. When done, I use Dust Off to blow as much liquid off as possible, and then let it sit for 5 minute. Then I popped both pieces back on the phone, and it worked like new. I'm in heaven now. Do it now if you're having a problem. I'm glad I did.
Posted on Sep 26, 2009
My blackberry has a mind of its own. itis opening up programs on it's own. it makes calls and sends text messages before i can finish.
Posted on Nov 04, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 10 Answers
A rollerball is also known as trackball or trkball, when I had a problem with mien I only used some "air spray" (like the one you buy when you clean your keyboard) and just clean the the trackball,while you at it, i recommend you clean the Blackberry keyboard also .
Posted on Jan 19, 2010
Dai thoma mobila thooki thanilla poodu roll ball work aagum(that means through your mobile in a water)
Posted on Dec 30, 2007
  • 846 Answers
The only way to fully get it up and running again is physically remove andclean (with alcohol) or replace the part. If you want somebody else to do it for you, goto Blackberry Trackball. If you want to do it yourself, here is a Blackberry Repair Guide that shows how, the part is available on Ebay.
Posted on Jul 19, 2010
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Rollerball not working
I had the same problem and it needs to be cleaned. I would suggest going to your service provider or giving RIM a call to find out the best way to clean it. I removed mine and cleaned it but ended up losing one of the little magnetic roller pins and will now be purchasing a new trackball.
Posted on Mar 07, 2009
My Rollerball won't scroll down - tried everything.
Cause: The sensitivity of the trackball/trackwheel might be less Faulty Hardware Resolution: Increase the sensitivity by following procedure Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100 If not working check with the service center
Aug 11, 2009 | RIM BlackBerry Pearl 8100
On the BB 8800.......you need to have the board service....this will solve the problem on your 8800 Blackberry.
the roll ball......on the pearl....you need to have the pad on the board replaced so take it to a professional mobile technician and have that done.
Jan 03, 2008 | RIM BlackBerry 8800
Rollerball assembly help
this link tells you how to put it back in the correct way...
http://jsdoodnauth.wordpress.com/2008/09/23/blackberry-pearl-trackball-stopped-working/
very good explanation includes pictures
May 04, 2009 | RIM BlackBerry Pearl 8100
My rollerball won't click.
I'm having the same problem with this. One of my friends and a Att worker have suggested that replacing the Rollerball with a new one which can be bought off Ebay for 5 or 6 bucks can fix the problem. If that does't work then check to see if water damage has taken place, if any moisture has gotten to the phone it may be that. Other then replacing the rollerball i have no other solution.
Apr 17, 2009 | RIM BlackBerry Pearl 8100
had same problem. used rubbing alcohol with a cotton swabb. Took a couple of applications, but worked brilliantly within 10 minutes. Thanks!
Mar 06, 2009 | RIM BlackBerry Pearl 8100
Rollerball of my blackberry8100 is nt working
Use Rubbing Alchohol on a Q-tip to clean the roller. This happens to me all of the time and this always solves the problem
Jan 28, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl turns off when i touch the rollerball
Try a different ball in the device they are fairly easy to remove. Borrow a friends entire track ball use nail file to remove the ring then look to make sure what way the mechanism and ring go back in and try your firends if his/hers works in your phone replace the defective part. 2b4daea.jpg fb71594.jpgeb3c8be.jpg
Dec 29, 2008 | RIM BlackBerry Pearl 8100
Blackberry Curve rollerball scrolls but will not select when push
Try removing the silver cover around the scroll ball, and remove the ball. There should be a little white square underneath it. If there is no white square, but a red square, then it could be water damage. I had the same issue with mine.
Dec 15, 2008 | RIM BlackBerry Pearl 8100
Blackberry rollerball
Hi guys I have the solution. I think all your trackballs are stuck. If you cant move it, take the silver ring off with a knife, take off the trackball and put rubbing alcohol on it wth a Q - tip until it works. Can some1 help me? My problem is titled My blackberry pearl wont load up.
May 16, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
19,972 people viewed this question
Top RIM Computers & Internet Experts
Ekse
Vincent G
Vincent G
ChrisChris70
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
