I purchased a 4gb memory card and when i playback photos on my camera it pops up thumbnails and will not let me go back through photos,when i put the 128 card in the camera it works fine.
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
The link refers to Panasonic's tests on Panasonic cards. Hardly surprising that all of them are compatible!.
Why would any SDHC card NOT be compatible with the camera if the card itself is not dodgy?
The manual specifies SDHC cards MUST be used for 4Gb and larger. For 2Gb and les, SD are OK.
My problem is that the 4Gb SDHC card works OK in the computer (and therefore is seemingly OK), but doesn't work in the camera. That is what I can't understand.
Hi - You will need to get an SDHC reader and then try the following procedure.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
SOURCE: I put a 4GB Sandisk SDHC card into my Panasonic
no way to solve...only SD is applicable...4G SDHC is not suitable for it
your sd card is sadly corrupted if you downloaded the pictures to your computer your in luck then get a new sd card and download all the pictures from the computer if its a labtop put the sd card on the bottom hope this helped vote thumbs up for more answers hope this helped
-Yashar G.
