Around 10 pm last night a little water got spilled on my aceraspire1 on the powerplug side i turned it off immediately and took out the battery and wiped every thing off throughly or at least thought i did in a lapse of judgement i turned it back on with just the ac cord for a bit and it started up fine and i logged in aswell it ran for a bit and i was going to grab some files on it off to my memory stick since i was doing a big homewrk project do monday well it start going little crazy soo i hit the power button and it was shutting down and got to the windows is saving your settings part but i unplugged it since i didnt think it had enough time i let it dry for the rest off the night and put it under some blankets this morning i turned it on and it starts up and shows the logo and then goes black screen with the little white slash on the top left and makes a loud long beepp noise with a clicking noise inbeetween it then it starts up agian and goes to the log in i logged in it worked fine i tested all the keys and they all worked and i just had to tell it to manually go to standby now so i logged out and logged back in then later i tried to log back in and my aswz buttons didnt work! which would have been ok except that my log in password requires the A button :( can someone helps me stop the beeping or help me fix my keys so i can log intt my acount please and thank u
It will continue to get worse and do a number of things. Moisture is really bad on dc pcb's. After it dries it will start to corrode. The best thing is do a full break down and remove and signs of corrosion. You may need to order a new keyboard. The long beep could indicate problems with either your ram or hard drive.
