Used this camera 3 times and now unable to get dvd out and i tried the reset button
I have yet to figure out this same issue 4 years later and still won't open. Can't finalize any of my DVD discs so I can't even watch the DVDs I was able to record before the door jammed shut. Someone told me wolf camera was a great repair shop. I've just not had the time. Anyone with any knowledge of this I'm at yahoo and email is... Rileygurlzmom
I have the same issue, on the DZ-BX35A, I cannot get the disk to eject. All other camera functions work fine. Tries using battery, AC power supply, camera on, camera off. Disk does not eject.
Have had this model camcorder just a little over a year & now door won't open. Is it worth the money to get it repaired - any idea how much it will cost.
hitachi dvd cam bx35a dvd door wont open problem. Tried several times and it is completely inoperable. Need help...
It gets stuck on disc access, but it won't access. The disc eject won't work as long as it's stuck on disc access. I've also tried everything, but nothing seems to work.
Same issue - basically. Battery was running low, screen said disc error and shut down. Now won't eject no matter what I try...
mine started 11 mos after purchase. gets stuck on disc access. reset button does nothing. using ac power or charged battery does nothing.
not really a solution but a suggestion. i have contacted hitachi about this problem....they advised me to remove the battery for about a minute, put the battery back in the camcorder hit reset and then hold the disc eject button for ten seconds...didnt work for me but might work for you...
Same as you all. Stuck in disc access, reset does not work. Tried to take it apart, apparently screws are under the disc tray to prevent taking off the door to get DVD out manually
