Acer 22" X223w LCD Monitor Logo
Posted on Oct 23, 2009
My Acer 22" flat panel monitor is blindingly bright, and I can't find a way to adjust it.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 26, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
321
Points
It cannot be dimmed much. I'm putting it back in the box to return.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
411
Points
Press the e button on the bottom of the screen (far left) and use the arrow buttons (2nd from right) to adjust the brightness.
1helpful
Screen too bright
The monitor should have a menu system that can allow you to adjust brightness as needed from time to time.
How to adjust monitor screen brightness?
hi. turn on the tv and then use the remote. click on the menu and scan thru til you find picture brightness or picture quality. J.
1helpful
Screen is too light, how do I darken
Press the 'OSD' (On Screen Display) button on the front/bottom of the LCD, to show a bunch of menu items. Choose "brightness", and adjust it to a darker value.
My hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Acermointors color is to bright
try to adjust front panel button, for the brightness control + - sign, if not function the problem is the lcd ckt. and need service.
2answers
How do I adjust brightness on Dell E152FP monitor
there's a buttong located on your monitor. just look for it then set up brightness to watever display u want.
How to fix 22 inch Acer hiorizontal distortion when set at max re
right click on your desktop... select properties.... when that window opens ... click on the tab that says settings. you will see a sliding adjustment there with different screen sizes.... experiment abit till you get the screen size that looks right and that you are comfortable with.
ACER LCD Monitor display is too bright!
I have my husband's hp monitor and thought I was going to go blind. I turned down the brightness to 0 and it still didn't help that much. I decided to turn down the contrast and it worked. Hope this helps.
Brightness adjustment not very effective - XP-sp2
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
