Kenwood KDC-135 CD Player Logo
Posted on Oct 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kenwood flash protect after i reset it - Kenwood KDC-135 CD Player
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 14, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
802
Points
Kenwood kdc-w4034y flahs "protect"
kenw392
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Kenwood Master 2,226 Answers
  • Posted on Oct 23, 2009
kenw392
Kenwood Master
Level 3:
Renaissance:
Answers
2226
Questions
Helped
473852
Points
4986
Sounds like it could be either a bad speaker, a shorted speaker wire, or a bad output ic inside the deck.
  • Paris Hayden
    Paris Hayden Dec 15, 2013
    how do you know what to check
1 Related Answer
Anonymous
  • 1126 Answers
  • Posted on Oct 15, 2009
SOURCE: My kenwood cd player is flashing protect. How do i
Page 33 on right side.
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDCMP2032.pdf
2answers
WE HAVE JUSTUST BOUGHT AND USED CAR AND IT HAS COME WITH A KENWOOD DDX-0512 RADIO/CD PLAYER BUT WE CANNOT GET IT TO WORK AS IT KEEPS FLASHING "PROTECT
There should be a code that the past owner forwarded you or left inside the owners manual. I found this great video on Youtube that should help you if your stuck. Good Luck.
https://www.youtube.com/watch?v=FjQiuy5wL6E&vl=en
My stereo keep flashing protect
hi johney, this function is an internal protection system linked to the amplifier circuit, there is either an internal fault OR a setting that must be reset by your kenwood repair agent OR there is a problem detected by your unit with the speaker wiring or the speakers directly. by yourself try resetting the unit to see what comes about, if the fauly persists then its best to refer to your kenwood repair agent. good luck. cheers.
1helpful
It just started flashing protect is there a reset button somewhere
"PROTECT" :- The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center. Reset is a tiny little hole hole to the right of preset buttons along bottom of unit, Insert paperclip to reset to factory settings?
Good luck with it
I am installing kenwood kdc-mp443u. it is flashing protect and i can't remove it. can you help please?
A speaker wire has a short-circuit, crossed, or touches the chassis of the vehicle it activates the protection mode function.
? Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
I have attached a link for you which is for a free Kenwood KDC-MP443U instruction manual download. Nice receiver by the way!
Kenwood KDC MP443U Instruction Manual
1helpful
2answers
My kenwood kdc-mp53u flashes PROTECT whats wrong with it?
Protect indicates that there is a short or a grounding problem usually within the speakers2_bing.gif or the speaker wiring. Locate and press the reset button (pinhole). If protect comes back then disconnect all speakers, reset and connect them back one at a time until protect shows up again. This will help you find out where the unwanted DC signal is coming from. If protect shows up when all speakers are disconnected, then it may need service.
When i hook it up the only thing it dose is flash the word protect
when its hook up press the tiny reset or go online to kenwood for the mater reset code for the model reciever you have that is a security feature kenwood has on its stereos when they are stolen only thing it doesnt know when the battery dies on a car or is removed. anyway kenwood has a master or check you manual. the preset station number are what you press for typing in the code.
62helpful
9answers
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
2helpful
2answers
Security
"Protect" isn't for security on a Kenwood; it's caused by a problem with the speaker output. There may be a defect in the CD player, or you may have a blown speaker or a shorted speaker wire in the vehicle. Try disconnecting all the speakers and see if the unit still shows "protect" when you turn it on. If it still shows the "protect" message with no speakers connected, the unit needs to be serviced; if not, re-connect the speakers one at a time until you find out which one is causing the problem.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
