Iomega (32453) External ZIP Drive Logo
Posted on Dec 31, 2007
Iomega zip drive problem
Zip drive is attached to IBM laptop (Thinkpad running XP pro) through the parallel port (printer port). The laptop will not recognize or read the zip drive.What am I doing wrong?
A
Anonymous
I'm trying to re-install iomegaware zip 100 & it tells me it does not support windows 2000 so I need to update drivers. Can you please help me figure this out as I rely on my zip for backups. I have version 21.1.
thanks very much
Marlene
Is there a windows 10 pro driver that works for seeing the older Iomega 100 parallel or Iomega 250?.. into a USB port on an hp elete 800 system?
OMG ZIP drives. wow (extreme legacy) 1994 made.
no, those ended 2 decades ago.
why not use USB memory sticks
or USB hdd or ssd docking ?
leave Iomega in the dust bin,
off the wiki it says.
quote:
Microsoft Windows family (Parallel drives not supported on Windows 7 and above)
Where can I get appropriate USB cable, i.e, parallel to USB not the original parallel to parallel?
So you have an old Zip drive with a parallel port? You can't connect that using USB. Nor can you connect that to a computer running any version of Windows newer than XP.
Two options:
1) Buy a USB version of the Zip drive and use it to read your disks. Used, USB Zip drives seem to run around $35 or so.
2) Get a computer using an old version of Windows. If it doesn't have a parallel port, you should be able to buy a PCI card with a parallel port on it.
Once you're able to access the files, copy them onto a USB thumb drive. For $10, you can get a 32 GB USB drive, which should hold everything from at least 320 Zip disks.
I own a 250 meg. parallel port external Zip drive. This drive could once be used on DOS-based computers with software called GUEST.EXE and some drivers, with GUEST selecting the correct driver and...
Recomendation: Replace for a external hard drive, The Zip drive is outdate. With theExternal HDD you gona have more space than a Zip drive, really much more.
I need soft ware for a paralle port iomega zip250 i am running windows xp
Go here to download drivers;
https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=16736&p_created=1107903170&p_sid=4AwppYXj&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD00NSw0NSZwX3Byb2RzPTEsMTImcF9jYXRzPTUwJnBfcHY9Mi4xMiZwX2N2PTEuNTAmcF9wYWdlPTE*&p_li=&p_topview=1
USB 250 zip drive not displayed
Hey, lost connection with you
Thanks,
Ekse
2answers
Iomega zip 100 external
hi
can you try reformatting that? it may readily upgrade itslef after reformatting it.
Top Iomega Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
