President HR-2510 will not transmit or recieve
Hi Darrel,
Since you didn't say if you have ever used this radio successfully before, I have to assume it is "new to you" and that you have never seen it work or used one like it before. Start with a few basic settings below:
Turn Squelch to minimum.
Set RF Gain (if present) to maximum
Set Mode to AM or FM
Set volume to 1/3 up
Connect to 50 ohm dummy load.
Turn power on. Hopefully you hear static. If not, try SSB or FM. Still nothing? Try connecting to an external speaker.
Chnage back to AM or FM mode. Key mic check & for transmit indicator. If none, change mic or manually short the PTT contacts in the mic or at the radio to see if it can be made to xmit.
If no xmit - insert SWR meter between xmitter and dummy load. Try to xmit on AM or FM again while watching SWR forward power, if none indicated, xmitter is probably defective.
Replacing parts in a xmitter is not recommended. You'll need an FCC license and a fair amount of expensive test equipment to test repairs, set power levels and deviation and perform an alignment to be sure you aren't causing interference on other frequencies and bands.
You'd be better off bringing it to a radio repair shop for repairs and an alignment.
ok. i have it hooked up to an external speaker, it works fine. but nothing out of the onboard speaker. must be blown.
My galaxy DX88HL does not have any sound out of the speaker nor the external speaker jack when the volume knob is turned all the way up you can barely hear any type of noise or receive but after a minute or so it starts popping I’m having a heckuva time figuring it out can you help?
