Start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Testimonial: "THANK YOU FOR TAKING THE TIME AND SHOWING ME HOW TO WIRE THE COMPONENTS TOGETHER. BUT I THERE MIGHT BE A PROBLEM WITH ONE OR MORE OF THE COMPONENTS."
I have fisher rs727 recevier and a kenwood km-106 amp and adc stereo eq sound shaper two how do i plug it together
The EQ is a Audio Source, model: EQ Eight / II.
having a problem with where exactly to plug in each of the jacks.
LETS LEAVE OUT THE AUDIO SOURCE EQ AND NOT USE THE KA-94 INT.AMP. FOR NOW.
THE KC-206 HAS AN EQ ON IT AND WILL USE THAT FOR NOW. AND WILL USE THIS CONTROL AMP ALONG WITH THE KM-106 POWER AMP WHICH IS ALREADY CONNECTED TOGETHER. I HAVE ALSO CONNECTED THE KD-64F TURN TABLE, KT-76 TUNER, DP-560 CD PLAYER FROM THE COMPONENT OUT TO THE INPUTS ON THE BACK OF THE KC-206 CONTROL AMP. THE SPEAKERS ARE ALSO HOOKED UP ON SPEAKER A OF THE KM-106 POWER AMP. NOT SURE WHERE TO HOOK UP THE RCA CABLES FROM THE KX-96W CASSETTE DECK. I'M ALSO HOPING THAT THIS WILL WORK WITH OUT THE REMOTE FOR THE KC-206 CONTROL AMP.
