SOURCE: Broken Zoom on Fuji Finepix F470
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom
button, the lens pushed out again and the camera worked normally for
that time. I had to go through that procedure every time I turned the
camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
SOURCE: Zoom Error
This would not be recommended by technicians but if you can not get any one to fix your lens you could try this, i have done this to a few cameras(which had been dropped) and they worked after. If the lens is obviously not straight and will not retract. Place the camera on a flat surface and starting gently pull lens to straighten it gradually increasing force until it clicks into the correct position. As i said you do this at your own risk, it will not work all the time but sometimes. Good luck
SOURCE: Accessories for Fuji Fine pix S5800
You Can not put additional flash on S5600, S5700 and S5800.
SOURCE: zoom on fuji f650 stuck
Hi Sandra, Try power reset for your camera. Turn the camera on, and without turning the camera off, open the battery door and take the batteries out. Leave it for a minute or two. This helps camera get reset and helps correct the basic functionality and also zoom error. Hope it helps u otherwise u will have to take it to authorised repair center. Good Luck.
