Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2.
Clean the gold contacts on the lens by GENTLY rubbing them with a
pencil eraser or soft cloth. Keeping the camera face pointing down,
also clean the gold contacts on the camera, being careful that you do
not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If
the “ERR 99" message only appears when one particular lens is attached,
then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
are there other possible solutions
