Question about Garden
Motor vibrates the entire mower, new motor pulley; belt and deck pulley replaced by serviceman. Continues to vibrate. Craftsman YTS 3000
  • 2 more comments
  • washumr Oct 29, 2009
    I have not heard from you guys, my last reply to you was, Oct. 24, 2009. The sh-a-ki-ng riding tractor. No damage to mower by owner.
    The motor shakes,when the blades are engaged only. This causes a severe vibration on the entire mower.It makes no difference if the mower is moving or sitting still, the vibration continues. Belts and pulleys were replaced by the serviceman, problem remained. No I did not hit anything, the mower was started and two days later,I ran the mower through the entire process and that is when I noticed the motor vibrating, once I engaged the blades. This is the second mower I have replaced this year but, this one took the CAKE. Thanks !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • lnbn1975 May 11, 2010
    If it is the motor vibrating bad, it must be an internal problem, more than likely caused, as Mr. Macgivor says, from hitting something and bending the crankshaft. If the mower runs so badly, missing, backfiring, etc, and that causes the shaking, then there is a problem that a tune-up or carb cleaning is in necessary. On his reply, Mr. Macgivor asked when the shaking occurs. When running? When in gear traveling? When the deck is engaged? All this info is needed to tell where the problem may lay.
    Wonder if you hit a fixed object and bent the crankshaft? Did it fibrate before the serviceman worked on it?
    New Friend:
Sears has a update to the deck vibration your service dealer should be able to get it took care of. we do warranty work for sears and they are aware of the fix
Posted on Aug 04, 2010
  • skipkeel Aug 04, 2010
    new engine pulley and belt should take care of this
    New Friend:
Well mine is doing same thing an it has new blades an all new bearings an belts runs smooh until blades are ingaged an then it shakes like a demon seems like i is coming from the motor area bu im not sure has anyone heard of the clutch doing this i put all this stuff on new to fix this problem an its still there
Posted on May 05, 2010
  • 204 Answers
OK, that clarifies the problem a bit. What I am going to suggest is that you take the deck off the machine if that is an easy task. While it is sitting free, or as low as you can make it go if you cannot get the deck off easliy, take any covers off the pulleys. I have a feeling that there is a bearing shot in the deck. Not a big problem, tho a common problem on Craftsman mowers, I understand. What you want to do is take each pulley and shake/turn/lift, etc, trying to see which one of them (I presume you have 2 or 3 blades on your mower). The bad one will be loose or act different that the others. There "may" be bearings on the top and bottom of the deck, I am not sure, but you will see where the shafts go thru the deck. When you find a bad one, take note of it's location and try to find a parts list so you can get a new one. May not have to go thru Craftsman/Sears to get it.
Did you call the technician to come to your house to repair the vibration/shake? Is this machine under warranty? Either way, if you did call him and he changed everything and you still have the problem I would suggest a call back and tell them that he didn't fix the problem and you would like him to return (at their expense).
Good Luck, and please advise your findings if this helps or not.
Posted on Oct 29, 2009
  • 234 Answers
Doesa the vibration happen when the cutting blades are engaged or do you still have vibration when blades are not turning? IF BLADES ARE TURNING AND YOU HAVE VIBRATION, YOU NEED NEW BLADES OR THEY GOT BENT FROM HITTING SOMETHING HARD AND NEED TO BE STRAIGHTENED OR REPLACED. If vibe is there when blades are still, possibly the output (crankshaft) is bent. Goodluck, Macgivor
Posted on Oct 24, 2009
6ya staff
SOURCE:
Why does the deck belt on my Craftsman rider SN 917.276863 come off. I purchesed an undersized belt and it comes off. Purchased a OE belt and it comes off.
be sure you dont have a pulley that is bent or loose. are the belt retainers still in place? the deck bearings are not wore out causing a vibration?
Sep 28, 2016 | Craftsman Garden
What would cause a heavy vibration on my craftman riding mower, not caused from the deck, but by the v-drive belt for the tractor. i replaced it and without even putting the mower deck back on the vi
You did not finish the statement about without the blades but if your saying what I thing you are...Ah Oh Sounds like you may have a bent crank..Did you hit something with the blades...take the belt off and start the motor..and Check for wobble of the V drive there should be NONE if it does it could be bent itself or the crank...good luck
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray Select Model # 405000X8 trong vibration when I engage mower deck. Also can't keep deck even.
Could be a number of things included but not limited to.....blade spindle bearings....idle pulley or engager pulley......could also have a bad spot in belt....causing a vibration. This vibration could also lead to deck coming out of level as that model have a leveling adjustment on the deck level control lever.
Oct 22, 2013 | Briggs & Stratton Garden
Vibration when I engage the deck.
Maybe the belt is too loose or tight. Check how much slack you have. My tractor was just vibrating really bad after putting on new belt it got better when I tightened it up.
Aug 13, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
VIBRATION-THRU SEAT & FOOT RESTS AFTER ENGAGING BLADE
get down and gun your fingers in the slot that the belt rides in, soulds like you may have a small rock or piece of wood lodged in the v part of one of the pulleys. I bet thats it Jim
Dec 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replacing belt from motor to double pulley by the transmission, I need help. This is on a Husky model number 13AZ608H131. Thank You for any help, rj22351@netsacpe.net
the 608h series unit have a variable speed pulley assy. and some have also a an ty vibration assay. fri st remove the deck belt from motor, take out the bolt engine pulley drop down remove belt, on the verbal loosen the bolt left the upper belt off and now left the center pulley up and remove the engine belt. should have the brake in lock posh ion fri st sorry. know if you have an an ty vibration pulley remove the spring and unbolt the pulley . feed the belt throw reassemble. hint have the deck in the full up posh ion for better removal. good luck
Oct 13, 2009 | Mtd Garden
I have a Craftsman Mower and blades won't engage
Yes, that would make a difference. I have seen the pivot point get rusted and dirty to the point that they wouldn't tension the belt enough. Locate the bolt where it pivots and loosen it just a little, then see if the belt gets tight. It must be really tight when engaged almost like a fan belt on your car in order for it to work. I would also recommend that you take a close look at your belt. It could be burned and have a flat spot since it has apparently been slipping. A flat spot on the belt will cause major vibration when the blades are turning.
Sep 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Clutch vibration and jerking at slow speeds.
Check the drive belt. It probably has chunks missing or at least has flat spots (narrow spots) that cause the belt to jump every time it goes around a pulley. That will set up a heck of a vibration. Also check the pulleys for free movement. The drive belt is above the blade drive belt....
Jul 27, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
694 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
