HI if your sony ericsson w200i mobile is locked to any particular GSM network then you can easily unlock it using sites like Unlocking4U.com here they are rendering unlock code for all mobile models at reliable cost .Else if your phone is locked by security code then reset your phone using default codes ....
Is your Sony Ericsson W200i having security lock code problem or network lock code problem? If you are here for security lock code first try the default codes like 0000, 1111 or 12345. If you are here for network lock code contact your service provider to get the code. If they failed to provide the code then get it from online providers itself. Get the code from the site Mobile-Unlocker.com ,and unlock it using unlocking instructions which is given in the site itself.
If you know pincode then it iTry Master Reset Code here possible otherwise you have to install its software for unlock.
Try Master Reset Code here http://www.unlocking4u.com/unlocking-services/rs6wp6/ For Your Model Mobile in the list. OR: You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved or: Contact your service provider to get a master reset code at free of cost.
First try default code like 12345 or 00000. If u have changed your lock code then Fixya provide u explained and good solutions Just Open
the following link and follow the steps carefully to know
your code. If u have occur any question or problem in this you can ask me. If it is helpful do Rate me. Keep using
Try the default lock code "0000" ,if this doesn't work you either have to take help of some websites that provide lock codes (for some bucks) ,if u provide IMEI number oruse your brain in a creative manner ,the code is definetely of 4 numbers.can try all permutations.
dear shir ! my name shiyam i buy new mobile phone sony ericsson i put lock coad in my phone after that i forget that now i want to open my phone please help me.
press frm joystick write side once then press*then 2times joystik left side then *then again frm write sidepress once u will go into service menu then u can see ur passward. no need of smcard when u do this.reply me
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery. I also need to know the network that the phone is locked on, and the country you’re in. Then I will give you the codes.
