LG WM-2277HW Front Load error code dE
De error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Generally it is the electronic door lock assembly failing. It is fairly
easy repair. Here is a video on how to do. http://www.appliancepartspros.com/lg-door-lock-switch-
6601er1004c-ap4441836.html#autoplay
You will need ti identify the correct part for your WM model.
Once you have that Google the lock part# for best pricing.
