SOURCE: i continue to have frost build up at the ice
make sure the flap is closing tightly or if its warn around the edge not alowing it to seal
SOURCE: 1. The water dispenser doesen't work. I can hear a
First try to unplug it
for an hour and then plug it back in. Also, make sure that the outlet
it is plugged into is working. Finally, clean the back of the unit.
There should be an exposed radiator pipe coil and a fan below. If it is
dirty or full of pet hair, it will shut down the compressor.
Most electronic equipment fails to work in an instant. Its better to
make sure they are tested once in a while through test equipments. It definitely sounds like your motherboard is bad.
This thread explains about it:
GE won't dispense ice (Motherboard Topic too)
Here's the motherboard for your model you can order:
Hope helps.
