Re: My front wheel is sticking on my buzz. It gets
Yes give it a good sqwert of WD40 and spin it round by hand till its free again it sounds like it may also be a bent shaft have you hit any big bumps? or has the baby put on a lot of wate?
In normal use, the front wheel needs to swivel freely - then this stroller's drive is easy and manageable with one hand (we know from extensive use with 2 kids and shopping on board).
The front wheel normally can not collide with the car. If the wheel assembly / lock is not correctly inserted, it can lock / unlock uncontrolled: try to disengage and mount the front wheel unit again.
Unsufficient tire pressure can also detoriate the drive.
There should be a master degree on the subject of using and folding strollers...
I do not know this stroller, but the try the link below.
On right hand top of the page you will find LIVE HELP... They should be able to help you solve this..
First remove the front wheel assembly from the pushchair by pressing in the two buttons on the sides and pulling it out.
Now look more closely at the assembly - on one side, just where it bends at an angle you will find a small hole, a couple of millimetres across. Take a small screwdriver or some other thin object and push it into the hole a little way, which presses a metal catch inwards, releasing the swivel assembly. While continuing to push this in pull the swivel assembly apart - grasp the wheels in one hand and the L-shaped plastic housing in the other and pull them apart.
Now clean all the surfaces with a piece of strong cloth.
When all the surfaces are very clean, take a can of TEFLON SPRAY and spray it onto all surfaces that rub against each other, before reassembling the wheel unit. Silicon grease is a cheaper alternative, but the teflon spray is supposed to be the best for lubricating all moving parts on the Buzz. Whatever you do, don't use WD40.
This is happening to my stroller and it turns out that the frame is bent. I have been unable to find a certified technician who is willing to fix it. I guess I can offer it for parts to someone.
You need to regularly lubricate the wheels...Just get some WD-40 with the little straw attachment & spray into where the wheel meets the frame...Make sure you lubricate the wheels regularly...I had the same problem & call Peg toll free - that was the answer & it fixed my problem too!!
