Victor 1208-2 Calculator Logo
Posted on Oct 24, 2009
I want to set the time and date on my calculator and need help Please give me the directions
sarahsue55
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Mar 23, 2010
sarahsue55
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
12902
Points
74
1)Press TIME/DATE and then SET (The first digit of the month will flash)2)Enter the month MM using the number keys.
(The first digit of the date will flash)
3)Enter the date DD using the number keys.
(The first digit of the year will flash)
4)Enter the year YYYY using the number keys.
5)Press SET to confirm the date.
6)Press TIME/DATE and then SET. Enter the time using the number keys and press 12/24 to switch between 12-hour or 24-hour clock.
7)Press AM/PM to toggle morning or afternoon and press SET to confirm the time.
  • Anonymous Oct 25, 2012
    Thank You so Much for your help!! I was going nutty trying to figure it out!!
6helpful
Setting date on Staples SPL-P500 calculator
You press TIME and then you have a button = (it's also written SET on it) press for few second, it will flash, you can now set the date, DD-MM-YYYY than =/SET than TIME again then, =/SET you can now set the time ( the button X / AM-PM to set am or pm) you press =/SET when you're done, and you're set !
6helpful
Cannot set date and time
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
4helpful
How to set time and date?
Setting the date:
Setting the time:
displayed.
13helpful
How do you set the date and clock?
Setting the date:
Setting the time:
displayed.
1helpful
SETTING THE DATE
Setting the date:
Setting the time:
displayed.
17helpful
Canon P200 DHIII calculator needs to be changed the date. Can you tell me how?
Setting the date:
Setting the time:
displayed.
Cant change the date
Setting the date:
Setting the time:
displayed.
4helpful
Changing the date.
Setting the date:
Setting the time:
displayed.
9helpful
I cannot set time and date help
I figured it out!!!! you push the time/date button once and then push the = (set) button and then it gives you the option to put in the day. Do the same thing again to put in the time also.
31helpful
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Top Victor Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
