SOURCE: the belt is sticking on my treadmill reebok TR3
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
SOURCE: Where can i find a
http://www.iconservice.com/index.html
The manuals are available here in PDF form.
Find your actual model number found on a sticker on the frame often found on the frame either in front or under the machine when folded.. It will start with an "R", usually 4 letters and 5 numbers..
SOURCE: user manual for reebok tr3
Dear Sir: I will try to help you. please go to web page for free: http://fitness.manualsonline.com another alternative you must pay: If you need further assistance, please reach me, sincerely.God bless you. E.CUADRA MANAGUA, NICARAGUA. C.A.
Dear Sir:
E.CUADRA
Manual here:http://userguides.50webs.com/reebok_tr3_...
I am trying to lift up the front from the walking surface but it would not lift
