Open up the washer, grab the metal basket and lift it up and down. If there is any play in it then buy a new washer. Replacing that spindle and bearing is not cheap. Spindle can only be purchased by also buying a new basket and that can cost $500.00 or more just in parts.
If this is what the inside drum does at all, then it is toast. Washer Spin Basket Part Number 131618500 Sears PartsDirect
This is the basket for your washer and it is $314
And if you decide to go that route then you will need the outer rear tub because the bearing is part of that tub and it is $246 Washer Outer Rear Tub Part Number 131462800 Sears PartsDirect You also have to ask yourself that since it is 9 years old, If I replace the tub and drum what else will go out? The motor? It's $120. What about the drain and re circulation pumps? Well it's $82. It will be cheaper on you to bite the bullet and purchase a new unit.
able to find a spec sheet on your specific washer, but i can tell you that you have a whirlpool made kenmore washer. and at 18 yrs ago they have only gotten larger, youd be hard pressed (unles you bought a apt sized machine or a laundry center) to get a smaller capacity machine. new machines are huge in comparison to the oldies
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
