Normally on printer.. Open front cover press back key machine show replace drum then press yes and off on printer iff error is still remove the drum unit and remove drum in drum unit and clean drum cleaning brush.. And also drum charging grid and reinstall drum unit and enjoy thank u
SOURCE: DO I NEED TO REPLACE MY DRUM WHEN DRUM END SOON
You can usually get extra life out of these drum units. Just open the front cover and press options then select 1 for drum replacement.
Good Luck and thank you for using Fixya.
SOURCE: dcp 7030 error toner replace..
the printer needs to be clean and restore the factory settings
SOURCE: drum end soon Brother DCP-7030
each replacable part has its own life of rotation, heat conversion ect. may be the life cycle of the drum reached to end. you need to replace the drum assembly.
