Duet whirlpool front loading automatic washer model: wfw9500tw01 getting a f35 error
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
What does the pressure switch look like and where is it when you remove the top
SEE IT HERE
Thanks!
see # #20 in THIS DIAGRAM for the location.
Right side at the rear.
Outside the normal analog pressure sensor (APS) / hose checks...
Another cause for the F35 and SUD error could be your CCU (control unit). There are components that seem to fail over time and cause the F35 and SUD errors. You can replace those components yourself now...
See f35error.com for more information.
Also use very little HE soap as well... Maybe a tablespoon or two at max.
I hope this helps!
Hello & Welcome to FixYa
F35 error means that there is some sort of issue
with the steamer electronic board and analog pressure sensor has gone bad.
Check that the hose is firmly attached with the washer and is not blocked. You
can also check the water level pressure switch operation. Please get back to me
if you have any other questions.
Kevin
Kevin
