Freezer working well we hear it working, but fridge not cold enough. Milk not cold enough. Cleaned outside of it in back and underneath to get all dust out of it.
I Have same Bosch fridge freezer. Fridge part not getting cold enough. Freezer part working, although motor seems to be running continuously. Have defrosted all - still the same.I Have same Bosch fridge freezer. Fridge part not getting cold enough. Freezer part working, although motor seems to be running continuously. Have defrosted all - still the same.
our kenmore side by side refrigerator is not cooling properly. It works but isn't cold. The freezer works fine and fan is running.our kenmore side by side refrigerator is not cooling properly. It works but isn't cold. The freezer works fine and fan is running.
You can't post conmments that contain an email address.
Check to see if the evaporator fan is working. It may be seized up and not blowing the cold air into the fridge compartment. Some GE have a air valve diverter which controls the air flow into the fridge. If the fan is working and there is no cold air into the fridge, this may be jammed in its closed position.
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues Here is a list of some things that can go wrong. 1. Defective heat coil 2. Defective defrost timer 3. Defective defrost sensor You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper. I hope this helps. Please let me know if I can assist you further.
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
