Simmons Outdoor AETEC 2.8-10x 44mm WA (2.8-10x44 mm) Logo
Posted on Oct 27, 2009
Mounting a Simmons Atec on 4x14x44 on a .22 .... shooting 4 inches to the left but have ran out of adjustment , turning to the right and is bottomed out, is there anything I can do ? Mounts are on correctly ...??????
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
211
Points
GET A SET OF MILLET RINGS. THEY CAN BE SET UP FOR THE LATERAL MOVEMENT YOU NEED TO ZERO YOUR SCOPE TO THE RIFLE.
We have a simmons crib n more and need bolts for it
Other than calling Simmons (good luck) your local hardware store should have
a selection of bolts that will work. Lowes is very good for this. Just take a headboard or
footboard, one siderail and size up the bolts you need. Most common are what are called
1/4 (quarter) 20 bolts. Pronounced Quarter Twenty as they are 1/4 inch wide with 20 threads
per inch. All you need is the right length and that will be between 2" and 4" depending.
Good luck, it's not hard to do. Go for it.
Hello, I have a Bushnell sportsman 3x9 mounted on a 22. I bought it new last year, but only took it to the range last week. I can't get the left/right cross hairs to move enough. At 25 yards, it shoots 9...
Start buy loosening the scope in the mounts. Loosen the front first to see if it is in a bind (left/right). Tighten it back down but not completely. Loosen the rear looking for some movement or popping sound. If you see a movement or notice some odd thing. check the mounting slots for dirt or dings that may cause an offset to the mount. If all is well. Go and start and zero for 13 - 15 yards. you want to be 1 1/2 inch hi. Now after each shot rap the scope with a screw driver handle or something solid, just to give the scope a shock not hard enough to bend it or dent it but shock it. Large scopes are meant for larger shock than a 22 produces, rapping the scope will help move the cross hairs and settle them in place. Hope this Fixya up. If it does help, please leave a testimonial. Thank you for using Fixya.
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
We were wondering the torque on the head bolts on a Kohler motor for a lawn mower.
Hi and welcome to FixYa. I am Kelly. These torques are from the Kohler Service manual for the
CV11-16,
CV460-465,
CV490-495
engine.
There are 5 bolts.... as you look at the bolts there should be 3 on the left side
Bolt 1 is the center (offset bolt)
Bolt 2 is upper right
Bolt 3 bottom left
Bolt 4 upper left
Bolt 5 lower right.
Torque them in the sequence above... to 15 Ft lbs. or 180 inch lbs
reset your torque wrench and then torque them to 30 Ft lbs or 360 inch lbs.
Rocker arms center nuts (called mounting screws) are first torqued to 55 inch lbs then to 100 inch lbs.
Then to set the valve lash you back off the set screw lock nut torque and set the valve lash to .003 - .005 final set screw lock nut torque is 65 inch lbs. Engine must be at TDC i.e piston all the way to the top to make the correct adjustments.
Thanks for using FixYa.
Kelly
Simmons aetec, put on muzzleloader to boresight and adjustments work in reverse.
It's a common misconception to think that you're moving the bullet impact on target, when in fact you're moving the scope's reticle to look where the rifle is shooting.... So if your shooting left of your target.. you want to move the crosshairs to the right.
Hope this helps, mark the Gunsmith
Please leave feedback, Thanks!
Jan 09, 2010 • Optics
3helpful
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. [email protected]
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
I am turning the knobs on my scope to adjust it because it is shooting low and left. The knobs aren;t working it seems, because my problem isn;t going away. What is wrong with my scope?
O.K work slow, tap on the scope with a med-small screw driver handle -- JUST TAP IT, do not bang on it, easy tap easy tap with every adjustment, work slow, move opposites. .
4helpful
3answers
Need a manual for a simmons rifle scope model # 1022
When you click on "customer service" on the simmonsoptics.com website, it takes you to the Bushnell customer service web page.
The number for customer service that is given is:
1-888-276-5945
The customer service rep. told me to "go to the Simmons web page".
Which, of course, takes me back to the Bushnell web page. It's a circular race track.......
In my opinion, Simmons/Bushnell has lousy customer service.
I bought a 2nd hand Simmons 3-9X50 scope (model #800479) that needed the screw on caps for the reticle adjustment screws. A small request, I thought.....one that should be easily remedied by calling Simmons/Bushnell customer support.
No dice. Customer support told me to spend $15 to send them the scope, and then they "will have to look around and find something that will fit."
Oh really??? Doesn't Simmons/Bushnell already KNOW the sizes of the parts they have?
Just send me the damn caps. They will cost Simmon/Bushnell no more than a buck apiece.
Then I asked for a user manual for said scope. No dice. The customer support lady told me to find the manual on the Simmons web page.
The Simmons web page doesn't provide user manuals online.
Their customer support needs a lot of improvement.
1helpful
2answers
I have a Bushnell Sprotiew 4x, 15mm scope mounted on a Mossburg .22 rifle. My shots are hitting left six inches and low. Can you please tell me how to adjust this scope? Thank you.
Keep in mind Diane this is for a set distance. if you are taking a shot at a target further than your are set for (ie a target you wont get 3 shots @) remember how the bullet is travelling as it goes down range
one idea would be to set your rifle up down range and zero it in on a target (preferably paper) now adjust 1 MOA (try and have target @ 100 yards and 200 yards)
see how far the bullet moves for each moa adjustment. then check it against the next range.
this should remain constant @ a set number of inches per 100 yards.
so if you zero in @ 100 yards and then move 1 moa any direction and it adjusts (lets say and hope it is 1.047 inches") then you do the same for 200 yards. it should be twice as much movement. ie 2.094"
once you know what 1 moa represents on your scope you can adjust alot more accurately.
REMEBER the total inches of movement / adjustment per MOA is directly related to range (a precise range helps in shooting) so if your squirrel is 150 yards and your first shot is off 9" to adjust you divide 9" by the inches per moa so 1.5 (150 yards /100) X (Inches per 100 yards per moa you measured hopefully 1.047") its 9" divided by 2x1.047 = 9" / 2.094 = 4.29799
this number needs to be rounded to the nearest click on your scope (most are 1/4 MOA scopes and you can tell by looking at how many clicks/lines are inbewteen each large number on your windage and elevation dials
so to turn this into an adjustment we round 4.29799 to 4.25 which is 4.25 MOA or 17 clicks on a 1/4 min scope.
GL and any questions just post and ill help
not please rate this as fixya :)
Note i can provide EXACT information that would allow you to determine range, and windage and elevation adjustments by looking through scope and estimating range
then factoring in weather variables. NOTE you hafta enjoy math or just want to know how to shoot really well. :)
Top Simmons Outdoor Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Simmons Outdoor Optic Expert? Answer questions, earn points and help others
