Question about HP LaserJet 1320 Printer
My hp laserjet 1320 fell off the desk and now will
My hp laserjet 1320 fell off the desk. When i try to print the paper feeds through but nothing prints. no ink on page
  • dreynolds377 Oct 28, 2009
    Thanks for answering my request. It feels like it is slightly warm. Now, the top light is also lit up in orange as well as the green ready light
  • ikkenom May 11, 2010
    Is the ejected paper WARM or COLD ? If COLD, then the fuser (which uses heat to bond the ink to the paper) is not working. Otherwise, it's broken, and needs to be taken to a qualified printer technician for diagnosis.
  • 53 Answers
Check to make sure if the ink or your toner is install properly becoz it might fell of its correct position.
Posted on Oct 27, 2009
6ya staff
SOURCE:
Paper Feed problem
I think its logic board related problem.
have a technician look onto it...
Nov 08, 2013 | HP LaserJet 1320 Printer
I want my hp laserjet 1320 to print front and back
Make sure the manula paper feed slot is closed.
Access Printer Properties or Printing Preferences
Select the Finishing Tab
Select Print on Both Sides
Select OK
Then print the document(s)
Nov 10, 2009 | HP LaserJet 1320 Printer
Printer will not pick paper
As a test, please try to print something using paper in the manual feed bin.
If that works, remove the tray, take all the paper out, verify the springs on the tray are working again then reinsert the paper and tray and try again.
Thank you.
Oct 04, 2009 | HP LaserJet 1320 Printer
I have a HP LaserJet 1320tn, after I changed the cartridge I keep getting paper jams just about where the paper meets the cartridge
Hi if you says that the paper gets jam at the fuser meeting point than i m sure that registration assembly which register the paper with toner cartridge is not working properly this is internal hardware fault.
It may caused due to faulty pickup assembly too.
There is a small **** manual feed tray try to print using manual feed and check if the problem persists then registration assembly is faulty if the it print fine from manual feed than Tray 2 pickup assembly or pickup roller is faulty.
Jun 29, 2009 | HP LaserJet 1320 Printer
HP LaserJet 1320 folds over top left corner of every page printed
I see this problem alot after a paper jam occurs and someone has pulled the stuck paper out. There is probably a piece of paper stuck in the printer somwhere. If you open the front toner door and take the cartridge out, you will see a roller at the bottom front. DON"T touch the roller but take it out. You may find the paper there!
May 24, 2009 | HP LaserJet 1320 Printer
My 2003 laser jet 1320 suddenly quit printing.
Good chance something is wrong with the tray, are you able to print of you place paper in the multi-purpose tray (tray 1)?
If so, one thing that may be your problem in tray 2 is here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00276974
Feb 28, 2009 | HP LaserJet 1320 Printer
Why is it printong crooked?
The problem can be with the software program. May be the formating of that particular text has been accidentally changed to italic. Or print the same on a plain A4 paper or slightly bigger paper than the check and see if you get the same problem.
Apr 22, 2008 | HP LaserJet 1320 Printer
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
Problem HP 1320 not responding
Try changing to a new USB cable
Jan 31, 2008 | HP LaserJet 1320 Printer
Paper jams
check the feed roll
Oct 05, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
194 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
