Acer X241Wsd Monitor Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When turn on it flashes for about 1 second, then
When turn on, it flashes for about 1 second, then goes blank. I've tried reinstalling the disk that came with it, but same problem.
Anonymous
Level 2:
New Friend:
  • Expert 44 Answers
  • Posted on Oct 27, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
44
Questions
Helped
14073
Points
141
This is probably a data problem...
try to access to monitors on-board menu (usually a small button beneath the screen)
if the menu comes up i would try in this order
a new vga cable
connected monitor to a different pc/laptop
wiggle your video card
try friends monitor on your pc
good luck, rate if useful
My kobo wont turn on
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 • iPhone Apps
1helpful
When i turn on the netbook computer it shows which step do you wont to do start normally safe mode all those ones when i click on one it shows the windows xp loading for a second then it flashes the blue...
Your boot files or windows installation is corrupt.
You may need a windows disc of the same version installed to fix it, if you dont have 1, or a recovery disk, you may be left with no option but to reinstall windows (You may need to buy 1)
No screen on start up on g4 notebook
Try reinstalling MacOS on your laptop, as far as I know, all Mac come with recovery disks. To boot of off a disk, make sure the disk is in the drive , reboot the computer, and press C while the chime is playing. You SHOULD be able to reinstall. What your describing usually happens to very old iMacs that have bad, incompatible, or no RAM installed. If none of the above works, take it to an Apple Store, they were very helpful when my iPod had a bad battery
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
4helpful
2answers
Camera turns on with a bit of a tremble but shutter locks
I have an 5D with the same problem, It looks like the Anti shake does not initialize properly, The only bypass I found that worked (except for a real repair) is to set the display light timeout for 5 seconds, The standby timout for 1 minute, Turn the camera off, and on again, Wait for 5 sec then the display goes blank, wait for 1 minute then the camera goes in standby, (light from CF card flashed red 1 time) Then touch any button to re-activate the camera and... voila... everything works, including taking normal pictures and the anti-shake !!! So it only takes a minute everytime to startup..
Blank screen frozen
Insert your Mac install disk 1 into your macbook, and restart the mac. While powering on, hold down the "C" key to boot from CD. This will take you to the Mac OS X Reinstallation window. If you are able to enter this mode, then it's just a corrupted install, and you'll need to reinstall. If you cannot enter this mode, then there may be some hardware errors on your macbook.
Comment back on if that worked. If not, we'll try some other things.
1helpful
2answers
Acer Aspire 5920 will not start up
Please try relaoding windows on it with a fresh cd . Looks like ur windows is gone corrupt or u have a bad hard drive . If u try to install with a windows cd u will know if ur hard drive is crashed and needs replacement . Please try it
Monitor goes blank less than a second after turning on.
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
