SOURCE: Transferring images on camera memery onto memory card.
I had the same problem, and I found after much playing and mostly accidental findings that I could do this by following these steps
1. Put an SD card in the camera. Will not work otherwise
2. Go into playback mode, where you view the pictures, button looks like an blue arrow pointing to the right
3. Press the round 4 way controller downwards, and a menu (that I have never seen before!) appears
4. Choose the 4th icon along on the top line and that will give you options to transfer from memory card to camera and the other way around.
SOURCE: Lock memory card in nokia 3110C
well......
i thnk there is no other way ad....
u can just reformat it all then u can reuse it back ad......
go to memory card option then reformat lo.....
try it...bye
aaRon
SOURCE: Memory card write protect?
point out a file to unprotect. and right click your mouse and go to properties and select it as archive (or) un hidden
if same problem
some virus cases try to scan or delete virus using some antivirus software. and try it
(or)
finaly go to formate your memory card.(in case your files or deleted) only use this as alost chance
by
yv sharma
SOURCE: restore phone but memory card not opening and show the password.
if you want to open the lock of memory card then just download a software fexplorer and open application there open c:// and there will be a file boot rename it as .txt and open in notepad there you will find your password
SOURCE: memory card cannot read by digital camera.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - go to format option- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
