SOURCE: olympus sp 350
Are you sure you finalized the firmware upgrade procedure according to the instructions? This sounds a little like you pulled the plug a little too soon... Have you done it according to these instructions: http://www.olympusamerica.com/cpg_section/OMfirm.asp And kept the camera connected until the update was 100 % complete? If you did everything right, try reseting the camera - take the batteries out for the day, and see if it helps. if you're back to step one(the reason you did the upgrade), try the firmware upgrade again. If still it doesn't work contact olympus, and I hope you have a valid warranty. Good luck
SOURCE: Olympus 550 UZ battery
I have been using energizer lithium batteries, and get well over 500 pictures (mixed flash/no flash)
SOURCE: Could I use my Canon bounce flash (550EX) with this Olympus Digital camera?
That's not possible because the hot shoe is not provided for the Canon hot shoe. You can change some wires in the Canon flasunit to let it think is an Olympus model ;)
regards,
Rob
SOURCE: Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the
point the light will turn on, when it starts flashing slide it off then
back on. Do this a few times so it charges a little, then you should be
fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
SOURCE: New batteries act flat in Olympus camera!
Do not use "ordinary" alkaline batteries. Try using rechargeable batteries like nickel cadmium or nickel metal hydride.
