I cannot believe it. Yesterday I could connected handycam to PC via firewire cable and through pop up I could select Adobe Premiere Pro and transfer video to PC. Today PC does not detect the handycam. After rebooting PC, switching handy-cam power switch to different positions still camcorder is not detected. Adobe Premiere Pro says on capture window: Capture Device Offline. In camcoder I can see "DV IN". I bought firewire cable yesterday. Did it fail just after a couple of hours of work? Possible. They manufacture such a **** these days. How to test the firewire? Or how to restore the connection? What am I missing? Your help is highly appreciated. Thank you very much.
SOURCE: unable to connect Sony DCR-PC3 handy cam to my pc
make sure that you are using the correct firewire plugs (4 pin on the camera and 4 or 6 pin on the computer depending on the computer). If you are sure you have all this correct, check your BIOS settings for a disabled media card or 1394 controller.
SOURCE: capturing video from a Sony minidv drc36 to a Dell precision
with sony mini dv handycam how to capture on pc
SOURCE: Sony DCR-HC52E connected with Firewire not detected in moviemaker
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
