Press the MENU/OK button to display the menu. Press cursor-left, use cursor-up/down to select the wrench icon, press cursor-right, select the third item on the menu (talking head icon), press cursor-right. use cursor-up/down to select the desired language, and press MENU/OK. Press the DISP/BACK button to exit the menus.
If you need a manual you may download a copy here.
Here you see how the menu pattern looks, and you can follow the visual cues to change the language to English. The menu layout is the same in every language. .
Press MENU/OK to display the menu. Use up/down to select SET. Press right to display the setup menu. Use left/right to select the wrench with the digit 2 next to it. Press down to enter the menu. The second item on that menu should be Language, so use up/down to select it, then press right to enter. One of the choices should be "English". Highlight it and press MENU/OK.
You can download English-language software from the manufacturer's web site at http://www.fujifilm.com/support/digital_cameras/software/
If you need an English-language manual, you can also download that from the manufacturer's web site at http://www.fujifilm.com/support/digital_cameras/manuals/#a
Press MENU/OK to bring up the menu. Press up/down to highlight SET and press right to bring up the setup menu. Select "LANG." from this menu, press right, and make your selection.
go into the setup menu ("set") by pressing the menu button, and look for the picture of a little man yelling (he's speaking). That's the language set-up. Set it for english.
The self-timer is accessed through the arrow dial. The little picture of the clock at the bottom of the dial is the timer setting. The camera must be in the shooting mode to use the timer, not in playback. Here's a link to the owner's manual http://www.fujifilm.ca/x3717.xml
