My camera shows a count of 757 pictures. I can only access about 200. The counter on the LCD screen shows 100-757. I am missing the remaining pictures. Can I get those back?
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
