Try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3
is in standby mode(red light) till you hear a double beep. sometimes
the ps3 does a beep then another beep and goes back into standby thsi
is fine just release the power and quikly press and hold it again till
you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby
again....release and hold power again.......beep .........double
beep...release power now you should be in recovery menu.
If the
system turns on but then turns itself off, beeps at you and flashes it's lights
at you then you have over heated the system. The GPU chip has probly pulled
itself away from the board. This will require you to diassemble the PS3...
