I can't go to bleutooth I can only mail picters on bleutooth I can't get something of somewan and I also don't no how I change my voice mail Thank you! ps. I'm sorry about my English I com from the netherlands and Im 12 years old so I have to lurn everything!
Which language do you speak I speak german and spanish maybe i can help you.
If the pin its blocked you should try to go to the company that provides the service.
Tracfone support should be able to reset your voice mail. You will loose all your messages due to privacy reasons, and will have to set up new voice mail from the phone, not alternate line.
There are three elements to voice mail; having a Panasonic brand voice mail system, recording the greetings, and setting call forward conditions. Which ones have you done?
The default access to voice mail is extension 500 on the intercom, but we used to use 165. When you dial it, the lady says "welcome to the Panasonic voice processing system". If she doesn't or you're asked for a password, or you have not done the tutorial, then you need to do that and it guides you to the setup of the greetings, name, and password change. After that, you dial *710x 500 (or your VM access) # on the inercom to set call forward to voice mail, with 4 being no answer (my preference since it gives me the option of answering the 2nd call or letting it fall to voice mail), or 5 for Busy/No Answer.
The message manager (mailbox 998) and the system owner (mailbox 999) has the ability to access and change how the voice mail system performs. The owner can change your name for the directory or reset your password and/or setup or delete your mailbox.
Select the model of your Uniden DECT 6.0 phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/ to get the manual.
Since you don't say what phone, what OS, or what carrier, I can only provide generalities. In the setup menu, look for the ringer or ring tone section. There's usually a setting for long or short, or something similar.
Pls fist put you sim in deffrent mobile and call to you number and you call is going to voice mail so going to voicemail so ok Thats you mobile problem but if you no going voice mail so active you voice mail device call to service proivedar of you network ...ok
Yes go into the settings of your voicemail for verizon.. Listen to the prompts and go into setting change your administration settings to turn off password
If you found this helpful Please rate Me Thank you
If you call into your voice mail you should get passed all the messages and it will say something to the fact of personal settings.. in there you can change your greeting.
Your programming is off by one hour. Check the system clock and make sure it is on local time. Some systems require a manual reset back and forth for daylight savings.If the clock wasn't corrected, this will account for the voice mail redirect. Thank You. Jerry
