I have a LG F1247 TD5 washing machine and I am getting the letters UE flashing and the cycle is not finishing - can you advise what this is and what I can do to rectify?
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
* Door not all the way closed * Loose electrical connections at door switch and pwb assembly * Door switch assembly is out of order * Gasket on door may be creased in
UE = Unbalance error.
try to use a low spin speed with loads like rugs, and try to get as even a load as possible. (ie: not just one rug) Don't wash rubber backed rugs, as the backing can break up and clog your machine.
Now, if you are successful washing with the lowest spin speed, you can hold the " Spin Speed " button in while pressing on the power button. Release power button. Now release the spin speed button. Now, press the spin speed button until the next higher spin speed from your last successful spin. Press start. Your washer should now pump out and attempt to reach the new spin speed, without adding any water. (usually about a 14 minute pump and spin cycle) Don't expect to be able to spin out rugs at a high spin speed.
this is what i just found on the internet... With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
• Water supply is not adequate in area. • Water supply taps are not completely open. • Water inlet hose is bent. • The filter of the inlet hose clogged.
Solution: Check another tap in the house. Fully open tap. Straighten hose. Check the filter of the inlet hose.
UE: • Load is too small. • Load is out of balance. • The appliance has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, after several attempts to restart the spin cycle the machine will stop and the error code will be displayed.
Solution: Add 1 or 2 similar items to help balance the load. Rearrange load to allow proper spinning. UE:
