My fuel pump went bad snd i hsve to put in a new one how do i do that
Need a couple of jacks some extra hands a couple of 2x2 pieces if plywood the tank is awkward around 5 +ft long --- open gas cap relieve pressure- disconnect neg battery cable- drain tank (siphon)-raise and support on stands-remove shield from tank-disconnect fuel lines (compression tool )-disconnect lines from fuel fill-set jacks and wood or able to borrow a transmission jack support tank remove tank strap bolts and straps lower tank slightly enough to reach top and disconnect elect connections from fuel pump lower tank and remove
