Motor runs fine and starts on first pull, but no juice out of generator. it's not the fuse, because we tested the voltage on the leads coming right out of the generator. We replaced a part that looked bad, it may be called an AVR module, and still no electricity. any idea on what to check next? Model Number is PM0497002 and Serial Number is F19610148. Thanks, Chad
Take a look at the fuse...if it seemed burnt then replace it.
if not.
then check the breaker...try connectting your voltmeter directly to the wire that goes into the breaker(directly to the +) and the other side to the regular (-).
if it read 220 volts then the breaker is down...so replace it...or you can use the outlet directly.
however if it didn't read any voltage,
then you should check the brushes...they are right next to the AVR module...(the two wires that come out of the AVR are connected to the brushes)
if the brushes are shattered or if there is no connection between each brush and it's connector then replace the brushes..
but if they seemed fine.then your problem is with the wires...trace every wire and check for continuity.
the problem has to be one of the things i mentioned.
