The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
Hi, If Power and Lamp lights blinking 'alternately' it shows problem of temperature arise abnormal and reason could be blocked fan or air flow in tv is insufficient to keep it cool. If Power and Lamp lights blinking simultaneously then it shows problem with lamp installation, need to inspect lamp cover is fixed in its position securely. Let me know both lights are blinking at same time on your tv? Thanks.
the hyperlink button doesn't seem to be working, but just copy and paste this link into your browser. It is linked directly to your tv's replacement bulb.
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
if you are not afraid to get in to the back of tv, the chassie has 4 different fans,you can unplug the tv remove all of the screws on the back,and remove the lamp door,there are about 5 plugs on the top of the chassie that plugs in the tv,donot unplug these plugs ,you can pull the chassie out of tv until you run out of wire on the plugs,then plug the tv in,turn the tv on, and you might hear the fan thats bad. If you are not comfortable with this call a repair man,the fans are not that expensive,and are pretty easy to change.i can guide you thru the replacement process if you need my help.
