I have a panasonic Lumix dmc-fs3 camera that I have barely used. Now when I put the memory card in it doesn't recognize it. When I turn the camera on it says "pictures will be recorded to built in memory" . When I try to copy the built in memory pics to the card, it won't let me access the "copy" function. Under the "format" function- it doesn't recognize the memory card either, instead asking if I want to delete the built in memory. Any suggestions?
The problem may be simpler to solve. Perhaps you never normally change the setting from iA (intelligent auto), but the wheel with settings can get moved by accident. If it goes around one place counter-clockwise, it puts it onto the built-in memory, it seems. I had the same problem, and it frustrated me for months!
OH MY LORD! You just saved my life! I have spent 2 weeks worrying about this! I even bought a new memory card thinking the one I had went bad from overuse or something! OH MY LORD! Never thought to check that stupid wheel! I clicked it once off the STUPID CLIPBOARD setting on the wheel and back to iA and BINGO! 3074 pictures available! I CANNOT THANK YOU ENOUGH! We leave for a beach vacation in 2 days and I thought I was doomed to take pics of our 18 month old's first real beach trip on a phone! THANK YOU!!!!!THANK YOU!!!!!THANK YOU!!!!!THANK YOU!!!!!THANK YOU!!!!!THANK YOU!!!!!THANK YOU!!!!!THANK YOU!!!!!THANK YOU!!!!!
thank you very much, it happened the same thing to me!!!
SOURCE: unable to view pics from memory card of lumix camera
hi i think your memory card is dead, just to make sure try it in something else. let me know Yvon chow !!!
SOURCE: lost manual
It is in this list of downloads:
http://service.us.panasonic.com/operman/findmanual.aspx?cat=CAM
SOURCE: Hi: I have a lumix/Panasonic DMC-FS3.
The manual states that you should format your card when you see this error. If the card has been externally formatted use the camera to format the card,
To format, set your selector dial to play (green), push the up button to get to the second screen, select format (right), slect "YES" when given "DELETE ALL MEMORY ON THE CARD"
SOURCE: our lumix dmc-fs3 camera says the memory card is
It should have a little switch on the side. You slide it down to lock, up to unlock.
SOURCE: My panasonic dmc-fs3 lumix is
In the setup menu, find "reset" and follow the on-screen instructions.
