You need to loosen the motor fitting or the pulley settings so that the belt can be place over the groove of the pullery and pushed forward so that it will fall into place.
If you use a small lever to wedge it will be easier to push it on to the pulley .
Place one end to the pulley and push forward.
Remove the rear panel of the washer.
You will see the heater element at the rear of the drum,it has 2 wires going to it.
The thermistor as it is called is located at the end of the element,, unplug the connector on the thermistor. and pull the old one out, refit new thermistor, and connector.
Plz rate my solution.
Thanks.
Hi, and welcome to Fixya.
F03 is indicating that the wash thermistor is open or short circuit.
The thermistor is part of the water heating circuit,so the only thing you can do is to test the heating element for continuity or an earth fault..If faulty, replace.
If it is o/k then you will have to call an engineer.
Thanks, And a merry xmas.
Error code f03 relates to the thermistor on the heating element.
This can be a faulty thermistor or bad contact between it and the control board.
Worst case scenario is a fault with the board which would mean a replacement.
Hope this helps & thanks for using Fixya
when the power is turned off for a period of 30 mins and then restored does the machine still display this error code as soon as you try and start the machine,o and by the way does the door lock?
