Copies on our Brother 2800 are coming out black. The first copy is a little black and then each page after that keeps getting darker and darker. Thanks
    President:
  • 1,126 Answers
I would suggest replacing the drum cartridge, sounds like your drum cleaning blade has failed.
Posted on Oct 30, 2009
6ya staff
SOURCE:
The fax is printing dark black all over the page
It seems that there no charge voltage when copies are made.First thing you can try is to replace the drum unit or the toner cartridge.If this doesn't help,there could be bad charge circuit board that needs to be replaced.
Oct 01, 2009 | Brother IntelliFAX 2800 Laser Fax
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Copies are coming out in various shades of black - like its smeared...
Most common cause is a dirty corona wire and or drum. If after cleaning the corona wire and drum the copies are still mostly black and smeared, the drum may be broken. Best of luck.
Greg
Jul 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Cleaned the drum by running the slider on Brother IntelliFax 2800
Clean the corona wire, reclean the drum, check the toner cartridge. The cartridge may not be positioned properly, causing extra toner to be displaced.
Jun 19, 2009 | Brother IntelliFAX 2800 Laser Fax
Each succeeding copy gets darker and darker
When was the drum replace? Recently? Could it be time again?
Was it a remanufactured unit?
Regardless of all that, It sounds to me like the drum is failing.
Feb 27, 2009 | Brother MFC 4800 All-In-One Laser Printer
Printing quality problem
HELLO! IF YOU ARE USING A GENERIC DRUM OR TONER, YOU WILL HAVE COPY QUALITY PROBLEMS
Jan 14, 2009 | Brother IntelliFax-2820 Laser Fax
Light copies
You may have your machine set to print in "toner save" mode. Check your machine settings by printing a list. Also, some generic toner cartridges have too much polymer in the mix and will print light copies. If you change back to OEM toner, you may have to change the drum too, as the extra polymer stays in the drum unit and weakens the mix.
Jun 04, 2008 | Brother IntelliFAX 2800 Laser Fax
Please help me
Needs fuser replaced from the sounds of it, but may be drum.
313b189.jpg Fuser above
Drum below
link to purchase
Dec 25, 2007 | Brother IntelliFAX 2800 Laser Fax
Copied pages are all black
Is is a lower end product for light duty use. You can try a new genuine OEM drum and or toner, but buying them both would cost as much as a new 2800. Can you print a internal report OK?If so, then your scanner is defective. A common problem with 2800,s
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Mar 24, 2007 | Brother IntelliFAX 2800 Laser Fax
jasbo
jasbo
Ekse
Marvin
Marvin
