Often it is very likely your portable battery, or charger / charger cords went bad.
Try running your laptop with no battery installed that is the battery removed. If the battery is very bad your PC may not power up at all even when plugged in for safety.
If you do not get any lights at all (LCD screen or others) running only on your charger, please test your charger on another similar laptop or have it checked at a store/ or with a meter. It may be out. A cord or wire may be broken on it (common problem also) - physical parts and batteries wear first.
You may also try another battery if available. Look for any signs of or smells of burning or overheating on any parts for more clues.
Replace any bad battery or charger.
