Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Posted on Oct 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Craftsman 1/2 hp screwdrive, model 139.53927 works fine on the wall switch but we can't set the remote; light goes on but doesn't blink upon completion of setting sequence 1)press/hold remote push button 2)press/release receiver smart button 3) **when opener lite flashes, release remote button**(nope!!??)
Anonymous
Level 3:
President:
  • Master 3,197 Answers
  • Posted on Oct 30, 2009
Anonymous
Master
Level 3:
President:
Answers
3197
Questions
Helped
1458207
Points
8183
The wall control is hard wired and doesn't use the receiver in the logic board which the remotes do. You most likely have a bad logic board.
Sears craftsman 1/2 hp. Door goes up with remote, but when button pushed to go down the light flashes and door doesn't move. If you push the wall mounted switch, the door goes down like normal. Works...
Check the sensors in the doorway. They should both have a small light that is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
1helpful
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
I have a 1/2 hp craftsman opener. Remotes work fine. Wired wall unit has a blinking light on the open button and will not work Lock pad and light pad work but not the operate pad.????
Try pressing and holding the lock button for 3 seconds to stop the light from blinking. Your wall control may be bad. Usually when that light is blinking it is the remotes that will not work.
2helpful
The green light on the wall switch is blinking constantly yet it works to open/close the door. The remote does not work. Any suggestions?
Press and hold the lock button on the wall control for 3 seconds. The light will stop blinking and your remotes will work.
1helpful
2answers
Older model 1/3 hp craftsman goes up not down with remote
Your door sensors are either bad or need simply to be aligned. They must be pointed at one another to work properly. Each of them has a small light that will be lit when they are pointed correctly.
1helpful
2answers
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
5helpful
My Craftsman 139.53879 remote won't learn the code of my 1/2 HP craftsman receiver type 132C2105-3B. I followed the directions to push the transmitter button and hold the receiver button down until the...
I have no idea what a 132C2105-3B is but try this. Hold the button down on the remote and then press and immediately release the smart/learn button. If the remote is the correct one for your opener it should work.
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
