Hi, having error 0150:0000000, Printer has been barely used but has printed (not sure why page count is 0's).
Would appreciate any help to resolve.
This is a common error but I have done heaps and fix has always been use clean formatted stick, get lastest engine firmware
copy to root of usb stick or CFlash card(side), power on printer with stick in socket I double check your copy engine firmware
I use engine S2F9_1000008002.x and system, S2F9_3000008002.bcmp . allow to complete, remove stick, youre done, if this fails and I've done probally 100 and yet to see a fail then try with CF card if that also fails then you will need new eprom from kyo
This error suggests eprom error the system firmware will need to but upgraded or reinstalled.
If it is new contact the store you purchased it from and tell them. If not contact Kyocera online and they will (or Should give you a dealer in your area)
Thanks J
Error 7410 - Drum unit non- installing error
The drum unit is not installed or not installed properly.
Install the drum unit (See page P.1-5-10 of your operation guide). See image below.
The numbers after 7410- are the number of pages printed on this printer.
Little more to add, I programmed a USB stick with the following files which did not resolve the problem.
S2F9_3000010004.bcmp
S2GA_1000010001
