Most likely a water line underneath unit or the water valve. If it’s coming from inside unit and running out door, then it’s a stopped up defrost drain
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Generally, this problem can be solved by replacing the water filter. The water filters have o-rings that self seal when installed. If you keep the same water filter to long those seals will start to leak. Fortunately for us, the water filter housing is right over the drip pan, and when it leaks it conveniently goes there.
To make sure take off the toe panel to the frig. If you have problems taking the toe panel off don't worry, they need to be yanked. Start on on side and really give it a tug. Once you get that off you will see how it clips in and you can remove the other side with ease.
Now, if it is not leaking currently, have someone get water from the dispenser while you are on the ground watching. You will be looking at the filter mind you, underneath the frig. You should be able to see it dripping right into the pan.
Now of course you could have another leak, but that is most likely what has happened. Passed that, you will have to see the leak to know what is leaking. You can get water from the dispenser, but if that doesn't work you will need to wait for the ice maker to make some ice. Then you can see if that is the problem.
To simply cut off the water supply to the ice maker you would just need to turn the ice maker to the off position. Then it would no longer ask for water :)
I looked up your frig and I did not see a filter. If you want to use one, you can install what is called an inline filter. This is simply a filter you install behind the frig attached to the water line going to the frig.
All you have to is unhook the water line from the frig, attach it to your newly bought inline filter, and install another water line on the other side of the filter and hook that back up to the frig!
So now you have a filter and two water lines :) Just make sure to point the filter the right way, the usually have an arrow on them. The water is supposed to flow through them in a certain direction.
check to make sure that the condensation pan is in its correct position,, somtimes when the unit is moved up steps it causes the pan to sit in there cocked or unlevel and will drain out excessively. or it may be a crack on the fill valve solinod where the water line connects to the fridge.. there will be a blue plasitc cover right where the water line connects to the frig and somtimes they crack and will only leak when the ice maker calls for water... pull out the frig and empty the ice tray and when you here it start to fill up the icemaker check around that solinoed be sure to use a bright flash light because sometimes the leak will be a little stream of water that is really hard to see sometimes you can only feel it with your fingers...I hope this helps......
i have a similar problem. my water dispenser worked perfectly with the origional filter for about 8 month . then there was a decrease in water output. i then changed the filter.this worked fine for about 2 weeks . changed the filter again 2 days of water output. i have since changed the filter 2 more time with the same results. i do not have a kinked line . i have had the refer for about 1 1/2 years. ice production is down also . any thoughts?
The issue is with length of the filter and the space behind the filter allowing it to bend.
Along with many people we put a lot of things in our frig. When you jam things into your frig they can hit the filter causing it to bend towards the back of the frig. The long filter becomes a lever putting extra force on the plastic threads on the filter causing them to crack and leak.
Luckly we noticed our leak early and did not have a big leak into the floor below. But when I was removing items from the frig to get to the filter we had just bought two big gallons of milk and one was jammed into the filter.
You can try to remember to not put to much on that side, but within a month you will for get. Best thing to do until GE comes up with a better filter is to tape a wedge to the filter that fills the space between the filter and the back of the frig. That way if you jam a big gallon milk into the filter it will not bend and crack.
