Like a lot of people...you didn't post your engine size....so out of these 11 photos, please choose the correct one for your application:
Accessory drive belt routing—1.8L (AEB/ATW/AWM) engines
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEG/AVH/AZG/need a diagram on how to refit fan belt - 9f61356.gifs without A/C
Accessneed a diagram on how to refit fan belt - 2d14e76.gifelt routing—1.9L diesel (ALH) engines without A/C
Accessory drive belt routing—1.9L diesel (ALH) engines with A/C
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEGneed a diagram on how to refit fan belt - 51400be.gifC) engines with A/C
Accessory drive belt routing—2.0L (ABA) engine withneed a diagram on how to refit fan belt - a5de70e.gif
Accessoneed a diagram on how to refit fan belt - cad2791.giflt routing—2.5L (BGP) engine with A/C
Accessory drive belt routing—2.8L (AFP/BDF) engines
Accessory drive belt routing—2.8L (ATQ) engines
Accessory drive belt routing—4.0L (BDP) engine
SOURCE: fan belt broke and i need a diagram to refit new
Are you sure that you don't have a diagram on any area around your engine you might look for one that would show you how to run it!
SOURCE: Diagram for alternator/pulley belt.
If the Tensioner will not Tighten the Belt, It will be one of two Things. Either the Belt is too Long or the Tensioner is Bad and needs to be Replaced. Please Rate My Response! Thanks!
SOURCE: I NEED A FAN BELT DIAGRAM
James,
Reply with an email address and I'll email it to you. FYI, my AllData only shows the 4.7 liter engine used from the 2002 model year and newer.
Charlie
SOURCE: need fan belt diagram for 95 toyota landcruzer...
My 95 land cruiser A/C is good sometimes for 2-3 hrs cold only and then compressor stop on my way from San Jose to Las Vegas trip. Again back to normal cold on the next day and back again with same routine problem. I check the compressor at 35psi normal and no leak. 1. Is that the compressor relay problem? 2. Where is the location or box of the relay switch compressor ? 3. What is the standard thermostat temp. for my truck? 4. What is the difference using lower temp and std. temp. thermostat? My temp. goes up even w/o A/C and then goes back to normal again. My solutions: 1. I installed new water pump , coolant, belts and radiator caps. Do you have any suggestion or remedy to my problem. Thank you and more power to the Auto Doctor.
