Most likely the input box that have the problems.Because the input box is another hurtle for the video signal to goes through to get to the tv.Take all the devices out of the input box hook it up directly to the tv should solved this problems.
Thats in your routing of the wires. The way the PS3 is set up it takes precedence, and there is really no way around it. You have to turn off or disconnect the ps3 while trying to record.
Sucks.. but its the way it is.
it sounds like you need a mpeg codec to play dvd the software you are using doesnot need that to play dvds but windows does you could try a software like power dvd 6.0 this have a mpeg driver included windows can use.then media player can also play dvd using the codec from power dvd
Set the TV to look for a signal on the same input your are hooking your dvd player to. Example, if your dvd is hooked to video 1, set the TV to show video 1 on the screen.
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
