Question about Vizio GV42L 42 in. LCD Television
Please describe your screen black only logo comes on i pulled plug to remove logo cannot use power switch to remove logo problem:
  • ekoicim Nov 03, 2009
    Please tell me how to cancel my free trial subscription
  • Vizio Master
  • 19,396 Answers
Hi.
All you can do is leaving the TV unplugged for fifteen or twenty minutes, in the attempt to drain power completely and reset it.
Also disconnect all video cables when you restart TV. If TV is still frozen and does not pass POST screen, then the TV eprom must be reflashed, or the mainboard replaced. This must be done by a technician.
Here all parts for your TV:Vizio TV Parts | ShopJimmy.
Try unplugging power and check video connections first.
Regards.
Posted on Oct 31, 2009
6ya staff
SOURCE:
I have a Vizio XVT3d474sv. My TCON went bad, only one side of the screen was working. I ordered a new TCON for it. I had been checking over other things and was lightly tapping areas to see if somethi
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Vizio XVT3D474SV 47 in. 3D LCD TV
My IPad is stuck with the apple logo on a black screen while resetting to factory settings. No more movement now. What to do?
Don't forget to plug in the power. And again, press home button and on / off switch, till it switches off. Then press the on / off button, till the Apple logo comes back, then release the button. It can take up to a minute, before the screen comes on.
Sep 27, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Screens shows but then gos black
Confirm that all the input cables at the back are securely plugged at the rear of the screen and PC/output source and that the image source is switched on and displaying an image. This can be done by switching your PC on and waiting five mins. Then check that the power for the screen is on. If this does not work, then let me know
Jan 31, 2014 | ASUS LCD Monitor
My LG55LE5500 suddenly stopped working this morning. Last night, we switched it off in proper working condition. This morning, when we switched in ON, only the initial LG logo screen comes and stays there...
Check whether the product is turned on. I Try another channel. The problem may be with the broadcast. I Is the power cord inserted into wall power outlet? I Check your antenna direction and/or location. I Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in. From the LG manual kolbrun
Sep 18, 2013 | LG 55LE5500 55 in. HDTV LED
Hi! I bought a new asus eb1505 4GB RAM 500G disc. I switched it on, it asked me for some settings (language, EULA etc.), I set an username and a password. Than it said it should restart. Ok. After...
What I would do is to on post pressing your PC's power on begin to click over and over till you see a screen the F8 key. Go into Safe Mode or you may be able to Start Windows Normally. If this does not work then you must either do a Recovery or Run Windows disk.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Aug 30, 2013 | ASUS EeeBox PC EB1505-B011M Intel Celeron...
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
NEW PURCHASE AND PLUGGED INTO AUTO TURNED ON AND GARMIN LOGO APPEARED AND THEN SCREEN WENT BLACK. DOES NOT WANT TO STAY ON. INTSTRUCTIONS SAY UNIT WILL PROMPT BUT NOTHING HAPPENS. IS THERE SOMETHING ELSE...
Yes!!! Please charge the unit overnight. You didn't say what model you have. If it's a 2xx series, plug in the charger and move the on/off switch momentarily to the left until you see the screen say charging. Set the unit down and the screen will go off. If you touch the screen again, it will come on. After charging is done, when you touch the screen it will say charging is complete. Remove the charger. If its' a 3xx or 6xx product, hold down the on/off power button until you get the charge screen.
- Jim
SHARCNET-USA
Dec 11, 2008 | Garmin GPS
Vizio GV42L 42 in. LCD Television Logo
369 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
