Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Chia, this is not a good one, F2 is a keypad failure or interface mismatch. You can try a couple of things. 1. unplug the washer for a minute and see if the code returns. 2. Remove the consol to access the control board, three screws on the backside and the consol lifts up. On the right side you will see the main board. On the right side of the board, center harness will be the interface ribbon cable. Reseat it a couple of times. If this doesn't work, I believe you will have to replace the touchpad. Catriver.
SOURCE: Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
SOURCE: kenmore elite HE3 problem code F70 - what does
F 70 error code indicates some kind of communication problem between the component electronics and the control electronics. Before calling a technician I suggest disconnecting power to the machine for about 30 minutes, reconnect it, and try again.
